You can control mail relays to the IIS Simple Mail Transport Protocol (SMTP) virtual server for tighter security. When the SMTP virtual server is openly accessible, a user can distribute unwanted email through it.
Configure SMTP virtual server relay restrictions to allow access only to 127.0.0.1 and to disallow all other computers. The restrictions allow only selected computers to relay messages through the SMTP virtual server. Other computers cannot relay messages to the SMTP virtual server even when they meet the requirements set in the Authentication dialog.
The Internet Information Services (IIS) 6.0 Manager window opens.
The server details are expanded. The SMTP Virtual Server appears under your server.
Note: If the SMTP Virtual Server is not visible, add the SMTP server feature.
The Default SMTP Virtual Server Properties dialog opens.
The Relay Restrictions dialog opens.
The Computer dialog opens.
The Relay Restrictions dialog shows 127.0.0.1 in the Computers list. The computer with the IP address 127.0.0.1 has the status of "Granted" in the Access column.
The SMTP Virtual Server Properties dialog opens. With the options you chose, only the listed computers can relay messages through the SMTP virtual server. Unlisted computers cannot relay messages to the SMTP virtual server even if they meet the requirements set in the Authentication dialog.
The SMTP Virtual Server Properties dialog closes.
